Hey I'm picking up an NZXT Phantom 630 and I was wondering, would a fan optimised for static pressure be better for cooling the GPU? If this is the case, would I be better off using a 120mm fan, disregarding the 200mm capability of the side panel? Thanks.
Still learning how to play Dota 2 :)
https://linustechtips.com/topic/104504-sp-side-fans/
Having a side intake fan is worth it. Best to leave it alone and have 2 120s in the front and 1 in the back.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/104504-sp-side-fans/#findComment-1397622
Sorry if I was unclear, I meant to say I'm putting in a fan regardless but what would be better? A static pressure optimised fan or something orientated towards CFM?
If you had too, I would say something with more CFM since there are no restrictions. Also find a way to cover up the intake otherwise you will get a lot of dust into your card or just use it as an exhaust.
https://linustechtips.com/topic/104504-sp-side-fans/#findComment-1397661
That's what I've always done in the past (CFM optimised), but I'm starting to learn a little more about fans so the question arose. I'll have to figure out some kind of dust filtering method for the side panel.
https://linustechtips.com/topic/104504-sp-side-fans/#findComment-1397704
There is one company that does custom fan filters, I will try and find them, or use pantyhose.
https://linustechtips.com/topic/104504-sp-side-fans/#findComment-1397847
