RGB fans with stuck LED's
Solved by Gareque,
I was able to sort it just now. Basically figured it mist be a power issue as the LED's remained on when the PC was turned off.
So if anyone else has this problem, I powered down the PC, unplugged the PSU until all power was gone from the capacitors, then started it up again. Works fine now.
Featured Topics
Sjokk ·
Posted in Troubleshooting2 -
4
Trembletop ·
Posted in Graphics Cards13 -
6
2
VA7EC ·
username1234 ·
Posted in New Builds and Planning14 -
Troxt ·
Posted in Troubleshooting4
play_circle_filled
Latest From ShortCircuit:
I'm a Huge Sucker for a Cool Gimmick - Epomaker DynaTab 75X & DynaTab 75
play_circle_filled
Latest From Mac Address:
The Apple Vision Pro Leaves a Mark (but not the right kind)
