I'm fairly new to overclocking but I recently build a PC with an AMD 2600 with the hopes of overclocking. I changed the multiplier to 38X and the voltage to 1.3V. These are the only changes I've made in BIOS. I wanted to test this before going up to 4GHz and the cinebench score i got was about 8 points lower than it was at at stock. Could I need more voltage going to the CPU? Do I need to change anything else?
https://linustechtips.com/topic/1042559-help-with-overclocking-a-2600/
Be careful with the voltage, Steve at GamersNexus showed that voltage going to the cpu can be higher than the voltage specified or shown in software https://youtu.be/iQB7ELwBbVI
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
I checked that video out, thanks for the link. I ended up boosting it up to 4.0GHz and dropping the voltage down to 1.2125V and everythings seems stable. Thanks for the help!
