Display Output Ports Problem
Go to solution Solved by Findiculous,
http://irisclasson.com/2012/06/16/re-cutting-an-old-vga-cable-to-fit-both-a-hdmi-and-vga-cable-on-my-laptop-asus-x53-x53sk-sx028v-for-two-external-monitors/
Basically you are going to cut off the sides to fit.
Edit:
Here is a video for it as well. The music is...interesting
Edit:
CPU
Intel® Core i9 9900K 8 Core 16 Threads
Motherboard
ASUS® ROG Strix Z390-E
Memory (RAM)
32GB Corsair Vengeance Pro RGB
Graphics Card
MSI RTX 2080 Gaming X Trio
1st Drive
500GB Samsung 970 EVO NVME
2nd Drive
1TB Samsung 970 EVO NVME
3rd Hard Disk
480GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 540MB/sR | 450MB/sW)
4th Hard Disk
2TB 3.5" SEAGATE SSHD, SATA 6Gb/s 7200 RPM
5th Hard Disk
Power Supply
CORSAIR 850W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor Cooling
Corsair H150i Pr 360mm AIO
Case:
Lian Li O11 Air
You might have to get handy with a file to remove some of the plastic. I cant say I have ever screwed in the little things, unless its in a really hard to get to place and has some strain on the cable. IMO they're useless for on a desk or whatever.
I make intelligent lights do cool things
Edit:
That was very helpful! Thank you!
