Minimum power supply required?
Go to solution Solved by madknight3,
Thanks everyone. On the PSU it said Max Wattage: 450 and Peak Wattage: 500. It was an 80+ bronze as well. The installation went well and everything seems fine.
I'm going to be heading over to a friends and seeing if I can install my old video card in his system. I just upgraded to a 770 and have no use for my MSI 560 Ti Hawk that's a couple years old. Since his system came with a GT 520, and he's not in a place to get something new for himself, I figured I'd just give him my card in the mean time. Should be a little upgrade for him.
He's not a tech savvy guy so the only specs I could get him to find out about his computer (pre-built I assume) before going and checking it out myself are:
  1. Intel Core i7-2600
  2. GT 520
  3. 8 GB Ram (not sure the kind or brand)
  4. 2 TB HDD (again, not sure the kind or brand)
I'm not sure what brand his power supply is, how many watts it has, or if it has the two 6 pin connectors required for the 560 Ti. I'm not expecting any more than the bare minimum power supply required to run the system so it probably wont be enough, but we'll see.
What would be the lowest wattage power supply I should attempt to install the card in if it has the connectors? If it doesn't have the proper 6 pin connectors but still has enough watts, should I use the 2 external power cables included?
https://linustechtips.com/topic/104215-minimum-power-supply-required/
You should be fine with a 500W. Heck, maybe even a 450W.
400W will be fine. Looks like your friend got stuck with an alienware by seeing those specs lol
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
Suggest a Corsair. 5 year warranty. I had a 520W for 2 years, I spilled water into it, mailed it to them, and they gave me a 650W because the 520 was out of production. I so love Corsair.
Maximum... Game
Windows 7 'til 2077 CPU Intel Core i7 920 @ 3.8GHz HSF Noctua NH-D14 GPU EVGA 780 TI ACX DISPLAY 2x ASUS VN248H-P RAM 6GB G.SKILL 1333Mhz MOBO ASUS P6T Deluxe SOUND ASUS Xonar Essence STX PHONES Sennhesier HD598 SSD Samsung 840 PRO 128GB HDD Western Digital Black PSU Corsair HX620 CASE Corsair Graphite 600T Artic White  MOUSE Corsair M65 Artic White KEYBOARD Corsair K70 MX Brown PAD Corsair MM200
You'll be perfectly fine with a 400w or bigger.
NZXT Phantom|FX-8320 @4.4GHz|Gigabyte 970A-UD3P|240GB SSD|2x 500GB HDD|16GB RAM|2x AMD MSI R9 270|2x 1080p IPS|Win 10
Dell Precision M4500 - Dell Latitude E4310 - HTC One M8
$200 Volvo 245
