Usb connected sound loop
Go to solution Solved by Jobbe03,
http://www.nirsoft.net/utils/usb_log_view.html
This should give you an idea of what is causing the sound.
Hello. The sound of an Usb device connected is looping in my headset. Its like an Usb device is connected every 5 seconds. I have tried to disconnect all the Usb devices, and I have restarted and fooled around with the sound setup.
Thanks  for all help!
Mpower, 3570k & Gtx Titan Black
https://linustechtips.com/topic/104205-usb-connected-sound-loop/
https://linustechtips.com/topic/104205-usb-connected-sound-loop/#findComment-1393669
Yeah it Works. Thanks for the help Jobbe03 :D
No problem :)
https://linustechtips.com/topic/104205-usb-connected-sound-loop/#findComment-1393746
