I recently installed my new SSD on my laptop, now i'm trying to use my old hard drive as a external hard drive. I purchased a enclosure and plugged it into my computer, nothing showed up. (not in disk management or anything, only in 'safely remove device'.. "Sata to USB3.0".)
So i have searched the interwebs and found that i must first partition and format the drive, being a newbie at this, i fiddled around with the hard drive yesterday with no positive results. Although, i have managed to have three separate drives off the one hard drive (Shown in my computer, i partitioned them i guess :S)
One is the main C: boot drive (360gb), one is a HHD recovery (about 1gb) and the third is the external partition that im trying to create (about 360gb).
I have the ability to do a fresh install and format of this hhd as i have no files i need and i have a multi boot usb.
The question i'm asking is; For a external drive to work, what are the format or partition requirements and how do i go about implementing them,
System Details;
It's a laptop (Toshiba)
It's running WIndows 8.
and yes i got the right enclosure, although it may be faulty! starting to think that anyway..
Any responses welcome, thanks.
post-54328-0-68011600-1390132443_thumb.p
post-54328-0-72999800-1390132459_thumb.p
https://linustechtips.com/topic/104175-partition-help-plez/
So you tried the partition editor or windows 8 equivalent
  • Cooler Master Storm Enforcer
  • I7 3770K @ Stock
  • Gigabyte Z77X-UD5H
  • AMD Radeon R9 290
  • Cooler Master Hyper 212+
  • 16gb Corsair Vengeance 1600mhz
  • 2x 1tb WD Green Drives (RAID 1)
  • 256gb Samsung 840
  • Peripherals
  • Logitech G502 Proteus Core
  • Ducky Shine 3 - Blue LED, Brown Switches
  • Samsung SyncMaster 2443
  • Custom Mousepad http://imgur.com/xJWASQM
  • Logitech G35
  • Altec Lansing Octane 7
https://linustechtips.com/topic/104175-partition-help-plez/#findComment-1393341
both.
UPDATE:
I opened up the "safely remove hardware" part that is showing the usb, and the hhd is being recognised there and now also in device manager AND task manager but not my computer, now what.
https://linustechtips.com/topic/104175-partition-help-plez/#findComment-1393348
both.
UPDATE:
Does the enclosure need drivers?
  • I7 3770K @ Stock
  • AMD Radeon R9 290
  • 256gb Samsung 840
  • Peripherals
  • Logitech G35
https://linustechtips.com/topic/104175-partition-help-plez/#findComment-1393357
According to Windows it does, but it can't find them. I can't see where i put the box to it, it was just a no -name brand though.
Hmm, There should be an update drivers button, you will need to find the box if that doesnt work
  • I7 3770K @ Stock
  • AMD Radeon R9 290
  • 256gb Samsung 840
  • Peripherals
  • Logitech G35
https://linustechtips.com/topic/104175-partition-help-plez/#findComment-1393441
yeah the button isn't finding any. ill go back to the store tomorrow and buy a second enclosure and also check the name on the box (they had heaps). So i can rule out what's affecting it.
https://linustechtips.com/topic/104175-partition-help-plez/#findComment-1393495
