Hello, I am planning on a build that uses the Corsair 570x case, ROG Ryujin 240mm AIO, and ROG Maximus Hero. I was wondering if there would be enough VRM and RAM clearance to mount the radiator on the top of the case. I know it is a very specific question, so if no-one knows is there a way to definitively find out? Thanks
(The fans being used are LL120's)
https://linustechtips.com/topic/1039795-top-radiator-clearance/
