Have your tried, dare I say, turning it off and on again? (Unless this is what your PC does as soon as you turn it on)
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1039629-help-please/#findComment-12351297
CPU
Intel® Core i9 9900K 8 Core 16 Threads
Motherboard
ASUS® ROG Strix Z390-E
Memory (RAM)
32GB Corsair Vengeance Pro RGB
Graphics Card
MSI RTX 2080 Gaming X Trio
1st Drive
500GB Samsung 970 EVO NVME
2nd Drive
1TB Samsung 970 EVO NVME
3rd Hard Disk
480GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 540MB/sR | 450MB/sW)
4th Hard Disk
2TB 3.5" SEAGATE SSHD, SATA 6Gb/s 7200 RPM
5th Hard Disk
Power Supply
CORSAIR 850W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor Cooling
Corsair H150i Pr 360mm AIO
Case:
Lian Li O11 Air
https://linustechtips.com/topic/1039629-help-please/#findComment-12351305
2 minutes ago, GingerThor said:
i can’t boot in safe mode either or i’m doing something wrong.
Depending on your board you might have to use a different key for safe mode. Esc, F8, F12, Del. Many different ones. But as one of the respondents on the reddit thread said, he just hard booted several times and it botted into troubleshoot options which allowed him to get into safe mode.
Whats your motherboard?
CPU
Motherboard
Memory (RAM)
Graphics Card
1st Drive
2nd Drive
3rd Hard Disk
4th Hard Disk
5th Hard Disk
Power Supply
Processor Cooling
Case:
Lian Li O11 Air
https://linustechtips.com/topic/1039629-help-please/#findComment-12351327
1 minute ago, GingerThor said:
asus b450 plus
https://www.asus.com/support/faq/1013074/
This might help then?
CPU
Motherboard
Memory (RAM)
Graphics Card
1st Drive
2nd Drive
3rd Hard Disk
4th Hard Disk
5th Hard Disk
Power Supply
Processor Cooling
Case:
Lian Li O11 Air
https://linustechtips.com/topic/1039629-help-please/#findComment-12351370
this is all i get, no safe mode.
Press F1 to run setup?
Your original image from the BSOD suggested and AMD driver fault. But im going to ask this anyway, have you tweaked any RAM settings or XMP profile in your Bios?
CPU
Motherboard
Memory (RAM)
Graphics Card
1st Drive
2nd Drive
3rd Hard Disk
4th Hard Disk
5th Hard Disk
Power Supply
Processor Cooling
Case:
Lian Li O11 Air
https://linustechtips.com/topic/1039629-help-please/#findComment-12351436
11 minutes ago, GingerThor said:
and now it brings me to the bios
Well now that you are in the BIOS you can get into safe mode in the advanced boot options.
Get into safe mode with networking and just remove all AMD drivers then restart.
CPU
Motherboard
Memory (RAM)
Graphics Card
1st Drive
2nd Drive
3rd Hard Disk
4th Hard Disk
5th Hard Disk
Power Supply
Processor Cooling
Case:
Lian Li O11 Air
https://linustechtips.com/topic/1039629-help-please/#findComment-12351506
6 minutes ago, GingerThor said:
how do i remove the drive from the bios i’m a ducking noob
No. Using the advanced boot options you should be able to choose to boot into safe mode directly. From there you will uninstall the drivers once you get into windows.
CPU
Motherboard
Memory (RAM)
Graphics Card
1st Drive
2nd Drive
3rd Hard Disk
4th Hard Disk
5th Hard Disk
Power Supply
Processor Cooling
Case:
Lian Li O11 Air
https://linustechtips.com/topic/1039629-help-please/#findComment-12351629
22 minutes ago, GingerThor said:
it never lets me into windows
Because even with advanced boot you get BSOD?
CPU
Motherboard
Memory (RAM)
Graphics Card
1st Drive
2nd Drive
3rd Hard Disk
4th Hard Disk
5th Hard Disk
Power Supply
Processor Cooling
Case:
Lian Li O11 Air
https://linustechtips.com/topic/1039629-help-please/#findComment-12351712
