Hi guys I'm rather new to computers and i have a problem with my radeon r9 270x .. after a driver update my windows stop working loads bios but at startup it goes black and it stqis like this .. ive contacted amd did unistall all with ddu and instal driver with out internet but still won't work .. ive found at one point a driver that worked but after a few hours display went black and windows restarted with black screen, rollbacked windows but cold not make it work againe ... Any help? Ps it works if i disable the driver from device manager and starts normal eith a higher resolution ... Pc specs : intel duql core e 5300 2.6 gh psu 500w 8gb  ddr3 of ram  and windows 7 . Thx in advance
https://linustechtips.com/topic/1034937-some-help-with-amd/
Sounds like a DDU " Display Drivers Uninstaller" might fix you.  Run it in safe mdoe clean and restart,, boot into normal mode and install latest AMD drivers and let us know.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1034937-some-help-with-amd/#findComment-12310622
