Hey guys,
I just did my yearly cleaning and after it started making a weird noise, it seems like it's a fan, but I tested them all 1 by 1 (Ionly have 4).
So far I have not been able to find the cause and the sound really makes me worry, if needed I can go on discord and maybe let you hear the sound.
It's really making me worried.
It's the first time that I got a prebuild system, it's from Hitech Gamer (pretty well known in Europe).
My specs are:
Intel I7 7700k (clocked at 4.8 Ghz) Stable for a year and a half getting close to 2
MSI z270 a pro
G.Skill 16GB 2400Mhz DDR4 15-15-15-35
Pallit GTX 1060 6Gb
Sk Hynix SSD (120GB)
1tb 7200rpm hd
2tb 7200rpm hd
Thanks in advance for the help guys
https://linustechtips.com/topic/1034885-weird-noise/
Best thing to do is unplug one thing at a time. I would recommend unplugging all of your fans first. if you still hear it then it is coming from a hard drive. If not, you know it is a fan. From there you can narrow it down further.
~Air Cooling Advocate~
https://linustechtips.com/topic/1034885-weird-noise/#findComment-12310112
I agree,  Noises are most of time fan noises gone south.  Like Votivee said liet us try to figure out which fan it is.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1034885-weird-noise/#findComment-12310134
