Hi,
I have a friend whose PC is having some unusual starting issues.
It starts all the time at my house, in any power socket, but at his house, it does not start at all (regardless of the power socket).
Motherboard lights come on at both our houses when plugged in, but when the power button is pressed on the PC case it does not start at his house.
The PC used to start just fine at his house, but now it doesn't start at all (with the exception of the motherboard lights when plugged in)
The powersupply is Corsair CX450, it has no switch on it to toggle between power voltages.
CPU - Ryzen 3 1200
GPU - MSI 1050ti
Motherboard - Asus ROG STRIX B350-F Gaming
We tried starting the PC without and with a monitor connected at each house, doesn't make a difference.
Any suggestions?
Thanks
https://linustechtips.com/topic/1034428-unusual-pc-starting-problems/
2 minutes ago, 1kv said:
The PC may be overloading his house's circuits.
One cause could be because he has gotten something like a toaster, washing machine, oven or tv and now the circuits are unable to supply enough power to the PC and the rest of the house.
no new appliances, should he try unplugging his GPU, case fans and other unnecessary components and try to see if it powers?
I'm not quite sure what it might be then. He could try unplugging his GPU to see if it'll boot. I wouldn't unplug case fans though.
Are you 100% certain his circuits are active? Can he plug in other stuff? Have you tried an outlet tester to check for wiring faults?
Does he have any arc-fault protected outlets? A single AFCI outlet will protect the entire circuit, so you may need to reset an outlet in a different room.
Intel 11700K - Gigabyte 3080 Ti- Gigabyte Z590 Aorus Pro - Sabrent Rocket NVME - Corsair 16GB DDR4
I was reading online to see how heat (natural) affects power, and people say it increases resistance in power circuits. We live in Australia, and we are having quite hot days at the moment since it's summer. This is the first summer the his PC has been through, and he lives in a small house with 5 sisters and his two parents. He's going to try unplugging his GPU and trying to power it then.
He's tried different power outlets around his house, nothing. Other stuff powers just fine from those outlets.
