I recently bought a new pair of headphones with a separate microphone, but whenever I plug a mic into my rig I get some really hideous static which seems to get louder over time. If any audio is playing through the headphones, the signal seems to be picked up by the mic and distorted. I've tried two microphones and both have had the issue.
The mic connects via 3.5mm mic jack, so if I were to guess at the problem, I'd guess my motherboard's audio was jacked up. That's not a surprise - the motherboard's pretty old at this point.
Has anyone had this issue? What is it and what causes it? What's the cheapest way I can fix it?
https://linustechtips.com/topic/1034221-onboard-audio-issues/
It might be a grounding issue. Can you check if there's any voltage on the grounding pin on your power strip? There shouldn't be any.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1034221-onboard-audio-issues/#findComment-12305223
