One of the fans on my Gigabyte G1 1060 6GB is making this weird clicking noise in the 40%-60% speed range.
It's similar in sound type to the clicking of a hard driver, and it's only on the left fan. Below 40% it doesn't exist, and above 60% it goes away. The right fan just had an issue of bumping against the shroud, which I fixed, but now that the louder sound is gone I can hear this one.
Does anyone have any recommendations? I was thinking lube, but knowing Gigabyte that'll probably void my warranty. It definitely sounds like it's in the bearing, not rubbing. I also checked the fan cable, it's clear. I don't think it would be worth the time without it for the RMA, so if nobody's got any suggestions I guess I'll just have to live with it.
Thanks, Alex.
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
https://linustechtips.com/topic/1031893-weird-gpu-fan-noise/
