The HDD attaches on the bottom by the power supply and you screw it from the bottom of the case. No need for a bay if it's one HDD
Also, is the h400 a better buy since it's cheaper and the smart device on the h400i doesn't work properly anyway?
RGB & Fan control ULTIMATE GUIDE !
https://linustechtips.com/topic/1028418-nzxt-h400i-help/#findComment-12254011
thats what i asked.. i need at least 2 hdds.. okk m gonna get h400.. but i need 2 hdds .. how do i fit? is there any way to accomodate 2 hdds inside h400?
https://linustechtips.com/topic/1028418-nzxt-h400i-help/#findComment-12254087
I don't know. I think you should innovate towards more SSDs and leave 1 of the 2 HDDs away
https://linustechtips.com/topic/1028418-nzxt-h400i-help/#findComment-12258096
