Posted January 31, 2019 So I overclocked my ram from 1866hz to 2133hz and now my pc will not boot. It will turn on but will not show video what should I do Link to comment https://linustechtips.com/topic/1028177-pc-will-not-boot/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 31, 2019 return the ram to normal? and slowly change it to you find the highest stable frequency you can get? that's the easiest fix. Rig 1: i7-9700k OC'd to 5.0ghz all core | EVGA XC RTX 2080Ti | ADATA DDR4 2400mhz 4x8gb | ASUS PRIME Z370-P | Asetek 550LC 120mm | ADATA 480GB SSD & Toshiba P300 3TB | Cooler Master Masterbox MB500 | Win 10 Home | Logitech G910 Orion Spectrum, G502 Proteus Spectrum, G933 Artemis Spectrum Snow Wireless Limited Edition, Corsair MM300 Mouse Pad | 2 MSI Optix Curved 27" FHD Monitors (before i sold the WD drive and MSI gpu - https://www.userbenchmark.com/UserRun/11946219 171 gaming. felt good.) Rig 2: i7-7700k Stock clocks | MSI Armor GTX 1070 | ADATA DDR4 2400mhz 2x8GB | MSI Z270 A-Pro | WD Green 240GB SSD & 2TB Seagate HDD | Thermaltake Core G21 Tempered Glass Edition | Win 10 Home | 2 HP Omen FHD 144hz 24.5" Monitors Rig 3: i7-6700 | GT 730 & GT 645 OEM | Some random DDR4 2133mhz 2x8gb sticks | OEM Dell Mobo | WD Black 2TB HDD & Toshiba 1TB HDD | Win 10 Home | 3 27" Dell FHD Monitors Rig 4: i7-4770 | EVGA SSC 1050ti | Some random DDR3 ram 2x2gb and 2x4gb sticks | OEM Dell Mobo | Stock Cooler | 1TB WD Black HDD | Win 7 Home RIP Rig 5 (dead and dismantled and sold) : i7-7820X OC'd to 4.8ghz all core | MSI DUKE 1080ti | ADATA DDR4 2400mhz 4x8gb | Gigabyte X299 UD4 PRO | Asetek 240mm AIO | WD Green 240gb SSD | Other various components that I can't remember Rig 6 (same fate as rig 5) : i7-8700k stock clocks | MSI DUKE 1080ti | ADATA DDR4 2400mhz 2x8gb | MSI Z370 A-Pro | Asetek 550LC 120mm | WD Green 240GB SSD & Toshiba 2TB HDD | Other various components that I can't Remember Link to comment https://linustechtips.com/topic/1028177-pc-will-not-boot/#findComment-12251704 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 31, 2019 I'm guessing its ddr3 memory? PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG Link to comment https://linustechtips.com/topic/1028177-pc-will-not-boot/#findComment-12251706 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 31, 2019 Author Yeah it is ddr3 but the problem is there is no output on my monitor so I can't change it back to 1886 Link to comment https://linustechtips.com/topic/1028177-pc-will-not-boot/#findComment-12251711 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 31, 2019 2 minutes ago, Kc D Richards said: Yeah it is ddr3 but the problem is there is no output on my monitor so I can't change it back to 1886 pull the CMOS battery or jump the pins. reset to default. Rig 1: i7-9700k OC'd to 5.0ghz all core | EVGA XC RTX 2080Ti | ADATA DDR4 2400mhz 4x8gb | ASUS PRIME Z370-P | Asetek 550LC 120mm | ADATA 480GB SSD & Toshiba P300 3TB | Cooler Master Masterbox MB500 | Win 10 Home | Logitech G910 Orion Spectrum, G502 Proteus Spectrum, G933 Artemis Spectrum Snow Wireless Limited Edition, Corsair MM300 Mouse Pad | 2 MSI Optix Curved 27" FHD Monitors (before i sold the WD drive and MSI gpu - https://www.userbenchmark.com/UserRun/11946219 171 gaming. felt good.) Rig 2: i7-7700k Stock clocks | MSI Armor GTX 1070 | ADATA DDR4 2400mhz 2x8GB | MSI Z270 A-Pro | WD Green 240GB SSD & 2TB Seagate HDD | Thermaltake Core G21 Tempered Glass Edition | Win 10 Home | 2 HP Omen FHD 144hz 24.5" Monitors Rig 3: i7-6700 | GT 730 & GT 645 OEM | Some random DDR4 2133mhz 2x8gb sticks | OEM Dell Mobo | WD Black 2TB HDD & Toshiba 1TB HDD | Win 10 Home | 3 27" Dell FHD Monitors Rig 4: i7-4770 | EVGA SSC 1050ti | Some random DDR3 ram 2x2gb and 2x4gb sticks | OEM Dell Mobo | Stock Cooler | 1TB WD Black HDD | Win 7 Home RIP Rig 5 (dead and dismantled and sold) : i7-7820X OC'd to 4.8ghz all core | MSI DUKE 1080ti | ADATA DDR4 2400mhz 4x8gb | Gigabyte X299 UD4 PRO | Asetek 240mm AIO | WD Green 240gb SSD | Other various components that I can't remember Rig 6 (same fate as rig 5) : i7-8700k stock clocks | MSI DUKE 1080ti | ADATA DDR4 2400mhz 2x8gb | MSI Z370 A-Pro | Asetek 550LC 120mm | WD Green 240GB SSD & Toshiba 2TB HDD | Other various components that I can't Remember Link to comment https://linustechtips.com/topic/1028177-pc-will-not-boot/#findComment-12251716 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 31, 2019 Author Okay I will try that thank you Link to comment https://linustechtips.com/topic/1028177-pc-will-not-boot/#findComment-12251735 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 31, 2019 Yea, 2133Mhz might be pushing it a little bit for ddr3 cause its factory clock is 1600 I think PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG Link to comment https://linustechtips.com/topic/1028177-pc-will-not-boot/#findComment-12251760 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 31, 2019 Author Ohhh okay Link to comment https://linustechtips.com/topic/1028177-pc-will-not-boot/#findComment-12251879 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 31, 2019 Author OMGGGG so I took out the cmos battery for around 10mins and put it back it and my system is working perfectly thank you to everyone with the suggestions Link to comment https://linustechtips.com/topic/1028177-pc-will-not-boot/#findComment-12251898 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
