Megalodon Razer headset problem
Solved by StareX,
Okay here is what you can do.
Go behind your PC and pull out the USB and replace it with 2 empty USB slots, but USB 2.0 not 3.0 .. I don't know why, but you can't have another USB device next to the USB of the Megalodon, it gives me.. problems.
Now, you can also click on the middle button, with the Razer logo, glowing blue one for 10 seconds, and it will reset your audio settings and mic settings to the factory settings.
Good?
