PHP PDO Sql connection from a Class.
Hi,
I'm trying to connect to my database and it doesn't work for some reason.
Why isn't this working? Woke up at 2am and now sitting and doing the login system.
userlist.php
include_once 'dbh.php';
class Users extends Dbh
    private $sql = 'SELECT id,username FROM users';
    function __construct()
        parent::__construct();
    public function getUsers(){
        return $this->conn->query($this->sql);
$users = new Users();
$result = $users->getUsers();
echo var_dump($result);
dbh.php
<?php
class Dbh
    private $host = '127.0.0.1';
    private $port = '3306';
    private $username = 'root';
    private $password = '123';
    private $dbname = 'loginsystemdb';
    private $charset = 'utf8mb4';
    protected $conn;
        try {
            $this->conn = new PDO("mysql:host=$this->host;port=$this->port;dbname=$this->dbname;charset=$this->charset", $this->username, $this->password);
            $this->conn->setAttribute(PDO::ATTR_ERRMODE, PDO::ERRMODE_EXCEPTION);
            return $conn;
        } catch (PDOException $e) {
            echo 'Mysql Connection failed: '.$e->getMessage();
AMD FX8320 | GTX660 | 4x4GB DDR3 | LG ZR2740W
Logitech Wireless Pro  | Logitech G413 | Nuforce uDAC5  | AKG K612
https://linustechtips.com/topic/1024461-php-pdo-sql-connection-from-a-class/
You should use the prepare method
<?php
$statement = $this->conn->prepare($this->sql);
$statement->execute();
return $statement->fetchAll(\PDO::FETCH_ASSOC);
Business Management Student @ University St. Gallen (Switzerland)
HomeServer: i7 4930k - GTX 1070ti - ASUS Rampage IV Gene - 32Gb Ram
Laptop: MacBook Pro Retina 15" 2018
Operating Systems (Virtualised using VMware): Windows Pro 10, Cent OS 7
Occupation: Software Engineer
