Trying to come up with some ideas, CPU seems a tad hotter then should be around 50-60c under load. GPU is 40-50c, sometimes spikes to 80-90c.
Any ideas of the issue?
PUMP-GPU-CPU-420RAD-240RAD-360RAD
CPU: i7 6700k
GPU: 1080 TI
Started to have issues after changing to PEGT Hard Pipe and changed fluid to EK-CryoFuel Blood Red Concentrate 100 mL
https://linustechtips.com/topic/1023961-water-cooling-loop-high-temps/
if your GPU temps stay between 40 and 50c normally then spike up to 80-90c randomly... sounds like you have air bubbles trapped somewhere, likely in your GPU block.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Cpu temps seem fine. But if the build just got filled again, prolly needs to be bleed properly.
Putting the pump on max and tilting the rig tends to help. Also hearing the trickling of water would tell you air is in the rads.
.... pump at max speed, tilt rig in each direction several times.
