Hello guys,
I have a Cooler Master Masterkeys Pro M and some times when I enter a game (it already happened in GTA V and PUBG, can't remember if it happened in other game as well)  the keyboard input behaves like I'm tapping the key instead of holding it.
For example, I'm holding W to walk and the character begins the animation of moving forward and then stops, over and over again.
The problem goes away if I press another key at the same time and release it afterwards.
I can't understand If this is a game optimization problem or a hardware problem, in which case keyboard or motherboard?
Troubleshooting I've done so far:
-Plug the keyboard into a different USB (problem continues, which leads me to believe the problem is with the keyboard);
-Unplug and re-plug the cable on the keyboard side (removable cable);
-Restart Windows
-I've also ran Radeon Overlay with CPU/GPU temperatures/usage and all that, everything seems normal.
Nothing of this worked, please help!
TIA
TL;DR: Having problems with interrupted keyboard input in games, troubleshooted some things but nothing worked! Please help!!
https://linustechtips.com/topic/1023693-input-problems-in-games/
