So reently, I upgraded (debatable) to a HyperX AlloyFPS froma Corsair STRAFE (Both cherry MX Red switches)
And I seem to  hhave ran into the same problem with both keyboards,  The key's eitherdon't register that they've been pressed or they double type,as in if I press K it'll register it as KK, My spacebar also presses twice.
The whole reason I got a new keyboard was because of  this issue in the first place.. I quite  liked my strafe and I just figured that the keyboard was faulty but now I question how good red switches really are as both keyboards from different brands are encountering the same problem, I owned the strafe for about 2 monnths before it started having the issue, and I only recently bought the AlloyFPS  (About  2 weeks ago, and it's already doing the same thing.)
My question is: Has anybody else every encountered a similar problem with Cherry MX Red  switches, and if so.. How did you fix it? Or any recommendations..
It's sooooooo annoying being in-gamme (Especially competitive games such as CS when I can't  press CTRL and it doesn't allow me to crouch)
(I purposely didn't correct any of the mistyping's just so you can see what I mean..)
CPU: Intel Core i7-4790K | GPU: GTX 1080Ti | Case: Corsair 750D Airflow | Motherboard: ASUS Maximus Formula VI | RAM: 16GB Vengeance Pro | PSU: Corsair AX860
SSD/HDD(s): SAMSUNG 850 EVO 120GB, SAMSUNG PM830 256GB, SEAGATE 6TB | Optical Drive: Sony Optiarc AD-5280S CB-PLUS
https://linustechtips.com/topic/1022794-cherry-mx-red-switches/
hmm, i have a strafe and the only problem i encounter is in CS Dangerzone,
I always alt-tab, becuase i try to use tab for the tablet, then want to crouch, but then I'm bad and miss the ctrl key, and hit alt, or if i want to exit the table while crouching, and hit alt-esc. XD
https://linustechtips.com/topic/1022794-cherry-mx-red-switches/#findComment-12204701
Well I wish I was just pressing the wrong buttons but sadly the buttons won't press until I smash them lol
https://linustechtips.com/topic/1022794-cherry-mx-red-switches/#findComment-12204708
