Hi my i7 8700k has randomly started rapidly fluctuating for no apparent reason. I've overclocked it to 4.7GHz a few months ago and a few hours a ago it has been fluctuating from 4.7Ghz all the way down to 1Ghz and everything in between. It is fluctuating whilst idling and when I play games it continues and my whole pc freezes. My temps are around 37c which are normal and I have no idea why it is doing this, any help would be appreciated.
Thanks
Edit: its is now fluctuating around 1-2GHz
Edit #2: my CPU temp has risen to 80c+ (from mid 30s) at idle and I haven't done anything to cause this
https://linustechtips.com/topic/1022031-need-help-with-cpu-speed/
Try start Prime95 smallFFT test, and monitor temps. If it goes higher or even shutdown then the CPU is overheating, most likely because the thermal paste dried up.
Desktop benching:
I'm doing the test now jsut wanted to add that my pc also randomly restarts without warning and comes back
2 hours ago, modestep15 said:
This is what it is doing
what board is this?
Desktop benching:
Just now, modestep15 said:
Asus ROG Maximus X Hero
maybe power management settings in Windows is in power save? Set that to high performance or balanced.
Desktop benching:
Just checked and it is already on balanced, the clock speed on my CPU is fine for about 5-10 mins when it first boots then it starts fluctuating like crazy.
Try blow air to the VRM heatsinks. Also make sure the core voltage isnt too high
Desktop benching:
All of my voltages (including core) are set to auto, I had overclocked my CPU to 4.7GHz which was the turbo clock so I didn't have to change the voltage. I've reset the clock speed to auto and the only voltage that isn't auto is the dram, for some reason it says 1.344w and when I try to change it to that is auto sets it a 1.500w and there's no auto option.
This is most likely the problem. this CPU turbo boost is up to 4.3GHz all core and 4.7GHz single core. Set the clock speed manually at 4.7GHz and turn off the auto, and set it manually between 1.15v-1.2v for that 4.7GHz, in my case, for 4.7GHz it needs 1.17v and I locked all cores at 4.7GHz with fixed 1.17v, stress tested it stable.
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
