PCI-e Network card issue
Solved by Guest,
30 minutes ago, WickedStarfish said:
I looked up your chipset:
https://ark.intel.com/products/94150/Intel-Dual-Band-Wireless-AC-8265
And according to the Intel site, bluetooth is only supported over the usb port of the card(where's wifi over pcie), which you presumably didn't connect or don't have the wires for.
You'll need to connect the internal cable of the card to your internal usb port. Beware that I'm not talking about the usb input port on the card, but about the black header and black cable that come with your card.
