I took out the heat sink in my computer to replace it with a water cooled cpu cooler. To prep for the install I took out the ram sticks and the graphics card. (What kind of worries me is when I tried to get the heat sink out it pulled out the cpu with it because the paste was so strong.) It didn't look like I bent any pins though and the cpu still sits in its slot properly. Once I got the water pump installed i went to boot up my pc. When I pressed the on button the psu turns on like normal, and the LEDs on the newly installed water pump come on, but there is no display and none of the case fans are spinning.
https://linustechtips.com/topic/1020512-i-need-help/
What CPU?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1020512-i-need-help/#findComment-12183901
