My PC: https://pcpartpicker.com/list/7fXNjy
I got a different Graphics Card and Power Supply and I was wondering if I should get better case fans to try to get lower temperatures.
Graphics Card: https://pcpartpicker.com/product/bq38TW/evga-video-card-06gp44996kr
Power Supply: https://pcpartpicker.com/product/JYxfrH/rosewill-power-supply-capstone750m
If you do have any case fan recommendations that would be compatible with my case you can let me know if you want to.
https://linustechtips.com/topic/1020411-case-fans-question/
2 front intake air flow
1 top intake airflow
1 back exhaust static pressure
Corsair got decent fans
You can go for Noctua, they are the best but they cost a bit..
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1020411-case-fans-question/#findComment-12183067
What are your temps?
https://linustechtips.com/topic/1020411-case-fans-question/#findComment-12183158
