USB Headers
Go to solution Solved by aaronhare,
10 minutes ago, Qwright10 said:
I have an ASUS Crosshair VI Hero and I have no idea where the USB 2.0 headers are. The specs says it has 2 2.0 headers mid-board, but I can’t find them. I have to have one for my AIO and one for front IO. Where are they?
Within the blue 16 on the picture attached there is a small label called USB1516. Each one is where the USB 2.0 and USB 3.0 header are located
This is shown in the manual which is located here: https://dlcdnets.asus.com/pub/ASUS/mb/SocketAM4/CROSSHAIR-VI-HERO/E12601_CROSSHAIR_VI_HERO_UM_V3_WEB.pdf?_ga=2.182336039.1470922495.1546738785-455947871.1521493389
They are at the bottom. I put a green line under what looks like usb2, but the photo isn't very good so I can't be sure so look at them yourself. USB 2.0 has 9 pins, the 10th one would be on the very edge.USB2.png.b2ee918bacb7fad1b3343c3a8596e288.png
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/1017667-usb-headers/#findComment-12158024
https://linustechtips.com/topic/1017667-usb-headers/#findComment-12158026
Better than my response. :)
My Rig
 Peripherals
https://linustechtips.com/topic/1017667-usb-headers/#findComment-12158035
