Yes, by a good amount.
A 3GB 1060 isnt worth the money right now though. You can get an 8GB RX 580 for the same price
https://linustechtips.com/topic/1017518-new-build-need-help/#findComment-12156575
A 3GB 1060 isnt worth its money right now though. You can get an 8GB RX 580 for the same price
or less...
I run a 1070 ti 8600k on that, so no. quality is much more important
https://linustechtips.com/topic/1017518-new-build-need-help/#findComment-12156580
13 minutes ago, coral_blue said:
So Im going to build a pc. And I dont know if a 550w power supply will be enough for a a gtx 1060 3gb and a overclocked ryzen 5 1600x. Should I go for a 600w power supply?
easily, an system builder might only use a 400 watt for a system like that. Not saying you should since the amount you save going less than 500 is not worth it IMO but you get the point.
https://linustechtips.com/topic/1017518-new-build-need-help/#findComment-12156616
I have a Corsair RM550x running an OC'd Ryzen 2700X and 2070RTX. never had the pc poop on me for power.
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1017518-new-build-need-help/#findComment-12156649
