Hi.
I want to put a 2nd fan on the cpu cooler (push/pull)
Here is the Mobo. yellow connectors are plugged in, green ones are free.
Where should i connect the fan?
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1016096-2nd-cpu-fan/
5 minutes ago, Constantin said:
Hi.
Best thing would be to get a splitter and run them both of CPU header.
https://linustechtips.com/topic/1016096-2nd-cpu-fan/#findComment-12143498
Well, waiting the splitter to arrive, i plugged it into the Pump connector, setting the RPM and curve identical to the CPU fan.
Everything run just fine.
Thank you guys!
https://linustechtips.com/topic/1016096-2nd-cpu-fan/#findComment-12143738
