Does anyone know where I can find an adapter that reverses the pins of an 24pin ATX connector? In essence I’m looking for a vertical adapter that puts the notch from one side to the other. One of my cables would greatly benefit from having the notch placed on the other side, but I don’t know if such an adapter exists.
Thanks.
https://linustechtips.com/topic/1014958-24-pin-reverse-adapter/
3 hours ago, jonnyGURU said:
There's no such adapter because it would reverse all the wires and fry a motherboard.  Dumbest idea ever.
I’m also implying that it would reverse the cables as well. Just putting the notch on the other side would be dumb indeed.
https://linustechtips.com/topic/1014958-24-pin-reverse-adapter/#findComment-12136148
2 hours ago, Cohacq said:
Just twist the cable when you're running it behind the motherboard.
I’m working in a case that has limited space and no cable route points. It’s not very flexible since it’s a short cablemod cable.
https://linustechtips.com/topic/1014958-24-pin-reverse-adapter/#findComment-12136155
  • 4 weeks later...
