I tried to overclock my RTX 2080 but it made the system unstable. I then used my CPUs graphics over HDMI to disable the overclock. But when i plugged back in my display port to my GPU I got no signal. I tried HDMI and it worked. I've tried updating the drivers, getting a new Display Port cable, trying a different machine, re-seating the GPU, and none of the 3 Display Ports are working. At this point, i have no idea what to do and I don't have another display with DP to test. If anyone has any ideas it would be very helpful.
https://linustechtips.com/topic/1013604-gpu-display-port-issue/
Reset cmos, first thing to do if something doesn't work.
Turn PC completely off, either flip psu switch or more easier, unplug the computer.
Remove cmos battery. https://duckduckgo.com/?q=cmos++battery&t=ffab&iax=images&ia=images
Wait 5-ish minutes.
Repalce cmos battery plug computer in and turn on.
This will reset any bios settings you have changed, so you'll have to change everything back.
Desktop:
CPU: Ryzen 5 1600 @3.75* RAM: 2 by 8gb G.Skill Flare X 2400 @2666* GPU Strix GTX 1070 @1880-ish
Storage: Samsung 860 Evo 500gb; 2x 2tb Seagate Barracuda Drives; 1tb hdd (It died after 4 years :();
Laptop: (HP Stream 11-y010nr "Spent all my money on my Desktop" Edition)
CPU: Intel Celeron N3060 @160 BILLION hertz RAM: 400 BILLION bytes Samsung DDR3L @160 BILLION hertz
GPUIntel HIGH DEFINITION Graphics @32 BILLION hertz
Storage: 32 TRILLION bytes of SOLID STATE emmc C drive with 64 TRILLION bytes of SOLID STATE microSD card D drive.
*Overclocked around 25% of the time... questionably stable.
https://linustechtips.com/topic/1013604-gpu-display-port-issue/#findComment-12124819
