5 minutes ago, MysteriousAeon said:
Do the fans spin? Is it a new purchase? That is exactly what happened when my R9 390 died. The PC would work fine when I plugged the monitor into the motherboard. You might need to RMA the card and get a replacement or a refund.
Yes fans spin and light up but nothing popup on screen.
https://linustechtips.com/topic/1013577-no-display-output/#findComment-12124699
2 minutes ago, MysteriousAeon said:
Are the PSU cables properly seated to the card? Have you tried another HDMI/DP slot on the GPU?
I used rx 580 which was working well and this 1070 is brand new. And there is no COMS on my mb...no jumper. My mobo is given in above link.
https://linustechtips.com/topic/1013577-no-display-output/#findComment-12124713
The 450 W PSU does seem like a bit low to me but I am not sure if it would cause a problem. Try clearing your CMOS. When I installed my new GTX 1080, my PC was stuck in a boot loop until I did that.
https://linustechtips.com/topic/1013577-no-display-output/#findComment-12124720
