I keep getting exclamation marks next to some cores on core temp when playing csgo only csgo other games such as rainbow are fine.
this is meant to show overheating?
go on my profile to check my specs.
is this bad? will it hurt my cpu? is there any way to downclock/undervoltage it to stop this from happening? no i will not do a repaste.
many thanks
https://linustechtips.com/topic/1013151-is-my-cpu-overheating/
Undervolt your CPU using Intel XTU
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1013151-is-my-cpu-overheating/#findComment-12121215
-Moved to CPUs, Motherboards, and Memory-
45C isn't a worrying temperature at all. If it's not thermal throttling and not straight up shutting down, I'd personally just leave it as is.
Is there a reason you're so against repasting it? Granted it shouldn't need repasting already anyway, but I'm just curious.
https://linustechtips.com/topic/1013151-is-my-cpu-overheating/#findComment-12121222
Those max temps are a different story, almost all at or above 90. That's definitely where the throttling kicks in
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1013151-is-my-cpu-overheating/#findComment-12121232
TJMAX is 100 by default with Intel with anything above 95 started to throttle down.
Learned all this today while playing with my own overclock!
CPU: Intel i-9 9900KF
Motherboard: Gigabyte Z390 Aorus Master
RAM: G.Skill 32GB 3200MHz Sniper X
GPU: ASUS ROG Strix RTX 2060
Case: Fractual Design Define S
Storage: Intel 760p 265GB SSD x2, Intel 760p 1TB SSD
PSU: Aerocool Project 7 650W
Display: ASUS VG278QR
Cooling: Noctua D-15S
Sound: ASUS Strix Soar
OS: Windows 10
https://linustechtips.com/topic/1013151-is-my-cpu-overheating/#findComment-12121243
Ignore the current temps, that’s at idle. Look at the temps that say ‘max’, that was during cs go. It reached 98 Celsius then core temp says it overheated by the exclamation mark next to it, I’m asking if that’s worrying.
Spent 2 grand on a pc only to have to take it part I don’t like the idea of that.
Also it voids warranty (or any warranty on the cpu/near cpu components) which I don’t want to risk just incase stuff does go wrong.
I will look at undervolting with intel XTU. Currently I think my cpu throttles to about 3.9ghz. Any clue how much I should undervolt?
https://linustechtips.com/topic/1013151-is-my-cpu-overheating/#findComment-12121432
Undervolting is your best option, then.
As well as trying to see if you can maximize airflow and maybe increase the fan curve by a bit.
https://linustechtips.com/topic/1013151-is-my-cpu-overheating/#findComment-12121437
I tried doing that but have no clue lol.
the Alienware. Built in software has horrible fan curve options as it only has 3 points on the curve to move and the backlash from each one is huge lol so it’s either too much or not enough and I tried using MSI afterburner but it didn’t let me change the fan speed for some reason and I googled around it said msi afterburner fan speed doesn’t change on laptops.
https://linustechtips.com/topic/1013151-is-my-cpu-overheating/#findComment-12121452
Try SpeedFan instead.
https://linustechtips.com/topic/1013151-is-my-cpu-overheating/#findComment-12121456
That sounds to me like those are 3pin fans being altered by voltages rather than 4pin PWM fans.  I don't know how long you've had the computer, but it might be worth checking any fans/heatsinks/radiators/filters for dust build up.  Gotta keep that cool air coming in and hot air getting out.
https://linustechtips.com/topic/1013151-is-my-cpu-overheating/#findComment-12121496
2 days lol
Ok thanks will try in the morning,
https://linustechtips.com/topic/1013151-is-my-cpu-overheating/#findComment-12121540
Well Intel mobile high end CPUs are toasty.
If you cant undervolt the chip you could try disabling turbo boost in bios or limit execution under windows to somewhere 80%.
Just understand that you will loose performance in exchange of less heat output. That CPU is just too much to cool down in a mobile device, and intel doesn't even care.
https://linustechtips.com/topic/1013151-is-my-cpu-overheating/#findComment-12121590
speedfan wont work i go to configure there are no fans to select and i cant add anything its all greyed out.
how much should i undervolt
i have done that now. Not sure if it made a difference to performance will check in a bit. Someone just told me it looses its settings the moment you restart. Is this true??
After running tests 100 mv undervoltage it seems to run stable at 68-73 Celsius package.
many thanks guys.
now I need to find something that will let me undervoltage permanently as XTU will just reset every time it restarts. Any ideas?
https://linustechtips.com/topic/1013151-is-my-cpu-overheating/#findComment-12122510
many thanks guys.
Can you not undervolt from the BIOS?
https://linustechtips.com/topic/1013151-is-my-cpu-overheating/#findComment-12123296
Can you give us the exact model you have there? I mean, laptops can get warm but gaming laptops have a lot more cooling. I'd really be p****d off if my new device thermal throttles in CS:Go. If it was a desktop system I'd already have contacted support or have sent it back.
Use the quote function when answering! Mark people directly if you want an answer from them!
https://linustechtips.com/topic/1013151-is-my-cpu-overheating/#findComment-12123585
Alienware 17 r5 go on my profile to view exact specs.
https://linustechtips.com/topic/1013151-is-my-cpu-overheating/#findComment-12123708
