  • 4 weeks later...
If your screen cover is plastic, use a microfiber cloth and a spray bottle with water. For monitors with a glass cover, you can use the same method and can get away with using a little Windex. Most importantly, DO NOT SPRAY DIRECTLY ON THE MONITOR. The liquids could most likely fall to the bottom where they can seep in and damage/kill it.
