Are you asking how to run it? If so, you may end up either renting a knuckle lift, genie lift, or using a really tall ladder. Though I'm going to assume you're running this over pews and won't have a wall to support a ladder. So you may need then a very tall A frame ladder. If you're asking how to secure it up there, that might be tough without more detail. Is the ceiling what you're saying is 30' high or the cable run is 30' long? All the runs I've ever done were in a drop ceiling, and legally had to be either going through conduit, or ran at the top of the trusses.
Out of curiosity, is this for a digital snake to a digital mixer?
https://linustechtips.com/topic/1010892-tall-ceiling-cable-run/#findComment-12103869
