No sound from GPU
Go to solution Solved by Lander-Peeters,
6 minutes ago, LoGiCalDrm said:
That monitor doesn't say, that it would support audio over DP, so probably doesn't. I don't know if using both would work, I don't think it will. You can try with picture-in-picture where you use two inputs at the same time.
Okay I’ll try that, thanks!
Hello guys,
I recently bought a new pc that I’ve build myself. Everything works fine but I have no sound unfortunately. I have tried some things allready but nothing works for me. So here I am, I hope some of you will be able to help me out.
More details:
I have an RTX 2080 from ASUS. When I use the GPU I have no sound coming from my monitor. When I use my motherboard everything works fine.
In detail:
When I use Nvidia high Definition audio, this is the audio output from the GPU, I hear no sound coming from my monitor. When I use Intel high definition audio, this is the audio output from my motherboard, I hear sound coming from my monitor.
Thanks in advance
Best regards,
Lander
https://linustechtips.com/topic/1009332-no-sound-from-gpu/
What monitor? Are you using HDMI to connect? While DisplayPort does carry sound, this needs to be supported by both monitor and GPU. Usually sound from GPU is routed with HDMI, or 3.5mm cable, but thats rare with modern cards.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1009332-no-sound-from-gpu/#findComment-12089343
My monitor: Asus mx34vq
I use DisplayPort. But could I use my DisplayPort for video and HDMI for audio?
https://linustechtips.com/topic/1009332-no-sound-from-gpu/#findComment-12089441
https://linustechtips.com/topic/1009332-no-sound-from-gpu/#findComment-12089473
https://linustechtips.com/topic/1009332-no-sound-from-gpu/#findComment-12089498
