So recently i bought a new computer. https://www.very.co.uk/cyberpower-armada-2080-intelreg-coretrade-i7-8700knbspprocessor-geforce-rtx-2080-graphics-16gbnbspram-2tbnbsphdd-amp-240gbnbspssd-vr-ready-gaming-pc-call-of-duty-black-ops-4/1600312843.prd?_requestid=77083&Ntt=cyberpower this is the computer i bought and i have been playing games on it and the fps is really bad. On black ops 4 i get a round 60 too 89 this is on default video setting and my friend is the same and he has a 1080 i7 4770k and he is getting around 150 frames. should i send this computer back and just say its faulty
https://linustechtips.com/topic/1008918-need-some-advice/
Return it and get your money back. I mean, just look at this:
  • Blue Tooth: N
  • Depth: 455 MM
  • Display Size: No Display
  • Dongle Required: N
  • Performance: Plays modern games at 4K resolution on the highest settings.
  • Processor: Liquid-cooled Intel i7-8700K
  • Graphics: Nvidia RTX 2080 8GB
  • RAM: 16GB 2400MHz DDR4
  • Storage: 240GB SSD + 2TB SATA III HDD
  • Wi-Fi: 802.11N
  • Operating System: Windows 10 Home
  • Warranty: 3-Year Manufacturer’s Warranty
  • Lighting: Blue LED
  • Graphics: Nvidia Geforce RTX 2080 8GB
  • Hard Drive Storage: 2 Tb
  • Height: 215 MM
  • Processor: Intel i7-8700K
  • RAM Memory: 16 GB
  • Width: 460 MM
  • Wifi Enabled: Y
What PSU is in it? What liquid cooling? What memory brand? What SSD and HDD brand? What GPU manufacturer? For all you know, it may have a bunch of aliexpress components in there.
And for some reason it lists all the specs twice. wat
God knows what components are actually in there and how they're set up.
Ryzen 1600x @4GHz
Asus GTX 1070 8GB @1900MHz
16 GB HyperX DDR4 @3000MHz
Asus Prime X370 Pro
Samsung 860 EVO 500GB
Noctua NH-U14S
Seasonic M12II 620W
+ four different mechanical drives.
https://linustechtips.com/topic/1008918-need-some-advice/#findComment-12086318
