One of the PC's at my work has been having a problem over the last few months where the mouse will just not work intermittently.  We've tried his mouse on other PC's and it works fine.  We've tried multiple other Mouses (mice?) on his PC and the same problem occurs.  We've tried different USB ports, they all work fine (all six of them) with the keyboard, or any other peripheral we plug into it...they just will not work with a mouse.
Any ideas?
It's an older Windows 7 HP machine.  Upgrading it isn't an option because it's not my computer, so there is that.  If there is a test i can run that would prove that one of the pieces of hardware is actually faulty, then I could possibly get an upgrade.  But for not, it seems to much to me like a software thing since all the ports and hardware work with every other type of peripheral.
Thanks
https://linustechtips.com/topic/1008310-help-with-co-workers-mouse/
Next time the problem occurs, try seeing if the windows key is responding. Could be temporary lock-up's
CPU: 2x E5620 - GPU: 2x GTX660 - RAM: 64gb DDR3 ECC - Mobo: Z800 OEM - Storage:1TB WD Green - 256gb - Micron C400 250gb - 850 EVO - 512gb 850 PRO
Monitors: 3x HP ZR2440W - Keyboard: G710 MX Blue - Mouse: MX Master
Keep up the good tone and stay classyxD
When it happens, the mouse is the only non responsive peripheral connected.  The keyboard, printer, credit card reader etc all work fine.
Wierd. Try a system reset(through windows recovery)
Hmm weird indeed, Try to use safe mode, It the mouse work in safe mode then just uninstall the driver and dont forget to tick "delete the driver software" option.
After that reboot the PC and try the mouse again.
Gaming Mouse Buying Guide (Technical Terms,Optical vs Laser,Mice Recommendation,Popular Mouse Sensor,Etc)
[LOGITECH G402 REVIEW]
I love Dark Souls lore, Mice and Milk tea  ^_^ Praise The Sun! \[T]/
I can conquer the world with one hand,As long as you hold the other -Unknown
Its better to enjoy your own company than expecting someone to make you happy -Mr Bean
No one is going to be with you forever,One day u'll have to walk alone -Hiromi aoki (avery)
BUT the one who love us never really leave us,You can always find them here -Sirius Black
Don't pity the dead,Pity the living and above all those who live without love -Albus Dumbledore
