Hello,
I'm new to PC gaming and had a quick question I'm hoping someone can help me with. If I had one stick of RAM containing 8gb. Could I potentially buy 2 4 gb sticks of the same brand and speed to double the ram? I know the practical thing would be to buy another 8gb stick but I'm curious if would run into any problems having 3 sticks for a total of 16 gb. Any help would be appreciated. Thank You
https://linustechtips.com/topic/1006828-question-regarding-ram-please-help/
Thanks for the help, I'm going to refrain from that. I do have one more question, if my motherboard specs say this... "Support for DDR4 3200(O.C.)/2933(O.C.)/2667*/2400/2133 MHz memory modules" Does this mean I cant use 3000 MHz? I see it states 3200, but it doesn't state 3000. This is probably a stupid question, sorry. I'm clueless. Thanks again
Your fine no worries on that.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
3 hours ago, Ronald Weezy said:
Hello,
While in the long run, yes just buying another 8 gig stick would be the "proper" upgrade.  Someone, please correct me if I'm wrong here, but if you are currently running your system with one 8 Gig stick of RAM, then you're running single channel anyway.  Wouldn't running two 4 Gig sticks allow him to run dual channel, effectively doubling the speed of his RAM?
