Hello LTT Forum,
I've been looking at the Raijintek mMrpheus II for my MSI Aero 1080ti though I'm not sure what sizes of the small heatsinks I would need for the mosfets, vrms and vram? Anyone could link me to something on eBay possibly? I'm well aware of I'll need thermal adhesive too. Thanks in advance!
https://linustechtips.com/topic/1005507-aftermarket-gpu-cooler/
With that cooler you wont need heat sinks on it as you will have direct air flow from the fin stack firing directly down onto it with the 120mm fans you have mounted.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1005507-aftermarket-gpu-cooler/#findComment-12055952
Don't the cooler come with small heatsinks for these small components?
Desktop benching:
https://linustechtips.com/topic/1005507-aftermarket-gpu-cooler/#findComment-12055958
7 minutes ago, Sidrilia said:
As far as I understood the Raijintek one doesn't? But the Arctic Accelero III does. But I might be wrong!
https://www.raijintek.com/en/products_detail.php?ProductID=46
It clearly says it does.
Quote
  • dot2-17.png24pcs heat-sink for RAM & 1 big heat-sink for VRM
  • dot2-17.pngThermal adhesive to lower RAM and VRM temperature significantly and assure proper bond
1080ti Aero only has 1 line of Vcore so you dont need more than 1 heatsink for VRM
Desktop benching:
https://linustechtips.com/topic/1005507-aftermarket-gpu-cooler/#findComment-12055982
Morpheus II will makes your graphics card to be 3.5  (nearly 4) slots thick with fans included
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
https://linustechtips.com/topic/1005507-aftermarket-gpu-cooler/#findComment-12059792
