Trying to make pinball using OpenGL the collision detection I am using in the code is not working at all
The collision detection i have implemented is in the layout.cpp and all the variables used is in ball.cpp(i have attached files with it)
I am using this formula to find the shortest distance of ball from the line:-
distance = |(p - a) * (p - b)| / |b - a|
( * operator used in the equation is cross product )
where p is position vector of center of ball , a and b are position vectors of endpoints of a line
please share if anyone have any other way of detecting collision in CPP.
layout.txt
ball.txt
My PC specs :- CPU i7- 8700k, Motherboard Maximus XI Hero,  RAM 32 GB Gskill Trident Z RGB, GPU Asus Rog Strix RTX 2080 , Case Phanteks enthoo evolv atx - tg edition, Storage 2 TB Seagate baracuda + 512GB samsung SSD, PSU corsair RMX 1000 Watt Gold PSU, Display(s) Acer Predator Z271U 27" WQHD Curved and Benq Zowie XL 2456, Cooling Asus ROG RYUO 240.
My Laptop :- Lenovo Y50-70 -CPU i7- 4710HQ, RAM 16 GB , GPU Gtx 860m 4GB, Storage 1TB HDD + 128GB SSD
https://linustechtips.com/topic/1003321-collision-detection-using-opengl/
The cross product only makes sense in 3d space.
You might have misread this answer; the formula you need is
[(p - a) . (p - b)] / |b - a|2
Where . is the dot product; this gives you the projection of the point on the line extended from the segment; you can then clamp the projection to the segment and work out the distance between that and the point.
sudo chmod -R 000 /*
I did some 2D graphics using STD DRAW and when I did collision I only really worried about circles.
Basically to stop from going to the edge I did
If (location + radius >= screen width)
//bounce.
I did have a few other things but I don’t recall what I did. If I have the files, I’ll post what I did. Java is close enough to C++ that you’ll understand what's going on.
Edit
I saw some books for cheap on amazon about 2D collision. Might be worth it.
