So the gist of it is I have an asrock ab350M pro 4 and a ryzen 2200g already in my closet brand new, my old rig after 10 years of faithful service completely died. So I'm looking for advice on what I could possibly upgrade to in a budget of about $300 USD, I would need a case, ram, video card, ssd, and a psu. I'll link a part picker of what I thought would be decent, thanks to anyone who takes the time to contribute!
https://linustechtips.com/topic/1003211-possible-build-advice/
Get memory with a higher frequency. 3000MHz or higher.
Get a better quality power supply. That Seasonic S12ii unit is almost a decade old now.
Reuse the case from your 'dead' computer to have enough money in the budget for a decent PSU and memory that won't kill the performance of Ryzen CPUs.
https://linustechtips.com/topic/1003211-possible-build-advice/#findComment-12034270
The case wouldn't be reusable comes from an old hp pre-built has no side panel I'm surprised it survived as long as it did being honest.
https://linustechtips.com/topic/1003211-possible-build-advice/#findComment-12034283
4 minutes ago, amusedschrodinger said:
120gb is a little slim for Windows. Can the budget handle more storage?
The hdd still works I believe haven't fully tested it but I'd be able to readjust at a later date this will be purely for gaming mainly league and siege so it's not too much of a big deal right now.
https://linustechtips.com/topic/1003211-possible-build-advice/#findComment-12034295
CPU: AMD - Ryzen 3 2200G 3.5 GHz Quad-Core Processor  ($0.00)
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard  ($0.00)
Memory: G.Skill - Aegis 8 GB (1 x 8 GB) DDR4-3000 Memory  ($56.99 @ Newegg)
Storage: MyDigitalSSD - BP5e Slim 7 240 GB 2.5" Solid State Drive  ($39.99 @ Amazon)
Video Card: PowerColor - Radeon RX 570 4 GB RED DRAGON Video Card  ($139.99 @ Newegg)
Case: DIYPC - DIY-F2-W MicroATX Mini Tower Case  ($36.97 @ Newegg)
Power Supply: Corsair - CXM 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($29.99 @ Newegg)
Total: $303.93
Generated by PCPartPicker 2018-12-03 06:19 EST-0500
https://linustechtips.com/topic/1003211-possible-build-advice/#findComment-12035079
