Help! Gaming Monitors?!?!?!
I’m looking to purchase 2 gaming monitors as a gift for Christmas. However, I’m not very tech savvy and really need help. I’d like it to be 4K. And thanks to YouTube I found ASUS VP28UQG 28”. The person I’m giving this to currently has an ASUS VN247H. Is this a good buy or is there a better option out there???? I’d really appreciate the help ❤️
https://linustechtips.com/topic/1003162-help-gaming-monitors/
depends on the game, high refresh rate is more often more important than high resolution.
Desktop benching:
https://linustechtips.com/topic/1003162-help-gaming-monitors/#findComment-12033793
Welcome to the Forums!
I've been using an Asus PB287Q. In simple terms, it's really good.
https://linustechtips.com/topic/1003162-help-gaming-monitors/#findComment-12033797
If you're willing to step down to 1440p 144Hz IPS, I'd recommend the Acer xf270hu. Plus you can get them dirt-cheap refurbished with a warranty either at Newegg or this Staples listing I found:
https://www.staples.com/Refurbished-Acer-27-Widescreen-LCD-IPS-Monitor-Display-WQHD-2560-x-1440-4-ms-144-Hz-XF270HU-Abmiidprzx/product_2710673
https://linustechtips.com/topic/1003162-help-gaming-monitors/#findComment-12033803
System
  • CPU
    I7 6700K Overclocked to 4.6 GHz at 1.33v
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
    GSKILL RIPJAWS V DDR4 16GB 3000MHZ
  • GPU
    MSI GTX 1070 GAMING X 8G overclocked to 2063 MHZ and 8900 MHZ memory clock
  • Case
    NZXT S340 RED
  • Storage
    WD 1TB BLUE AND SAMSUNG EVO 250GB SSD
  • PSU
    EVGA 650W GQ
  • Display(s)
    LG 25UM58-P ULTRAWIDE and LG 29UM58-P 29 ULTRAWIDE
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
    LOGITECH G502 PROTEUS SPECTRUM
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/1003162-help-gaming-monitors/#findComment-12033806
Y'all have been very helpful! I now know to look at refresh rate! I've watched a couple videos including Linus's ASUS ROG Swift PG27UQ video. However I need to buy 2 monitors and $4000 is a ton of money! Even though it's a beast of monitor!!!! I was looking at the BenQ EL2870U... I'd preferably like to stay under $1000. Thank you for all your help!!!! Please send anymore suggestion! We have a ton of time before Christmas ❤️
https://linustechtips.com/topic/1003162-help-gaming-monitors/#findComment-12033941
