When searching for files on the F and L drives, it works properly and I am given a result. However, when I search on the C drive, it returns no results, ever. So I checked my indexing settings, made sure the C drive was selected and rebuilt the index. Still, searches turned no results. I did this multiple times. I also tried restarting the Windows Search service and changing policies in the Group Policy editor to no avail. Then I noticed something when deselecting the drive in the indexing menu: When the drive is deselected in the upper menu ("Change selected locations") the drive disappears from the lower menu ("Summary of selected locations") even though the drive is still selected in the upper menu. Also, when the F drive is deselected in the upper menu but C is selected, F still appears in the lower menu. When both and are deselected, F doesn't appear in the lower menu. It seems like drives and F are connected somehow. I still have yet to find a way to index on my drive.
Example of when is deselected but then disappears.
Example of when is deselected but it still appears in the lower menu.
And an example of when both drives are deselected, disappears.
https://linustechtips.com/topic/1002795-search-indexing-problems/
Have you tried selecting show all locations yet?
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
1 minute ago, GenericPNP said:
Does nothing but show some old directories
-snip-
I'm assuming your C drive is an SSD? Samsung?
|King Of The Lost|
Just now, GenericPNP said:
That would be correct
samsung magician probably disabled indexing on the drive completely ?
|King Of The Lost|
