So, I ordered a fractal define meshify c mini a few days ago and apparently it arrived at midnight yesterday. Because of this it was left outside in the rain for a while. I have a roofed front porch but strangely the package was left in front of my garage. Long story short, my case was dripping wet when I unboxed it, so I checked the io pcb and found what seems to be water damage. Can someone perhaps more familiar with the subject inform me if this is indeed water damage, or just residue from the factory? As for the rest of the case water didn't contact any other cables or touch the fans, so the pcb is my only concern.
https://linustechtips.com/topic/1002625-water-damaged-case/
Does it work?
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/1002625-water-damaged-case/#findComment-12029607
Just now, CasualGamer... said:
I would have to take out my current pc's motherboard and test it with the new case to find out. I don't have any other way of determining if it works or not.
JUST... DO IT
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/1002625-water-damaged-case/#findComment-12029617
Let it dry overnight, it'll work even if it's water damaged. I wash my PCB everyday when doing soldering jobs
CPU: i7 5930K OC'd 4.5Ghz
Motherboard: Asus X99 Sabertooth
RAM: 64G Corsair Dominator Platinum
GPU: EVGA GTX980Ti Hybrid
Case: NZXT H440 Razer Edition
Boot: Intel 750 480GB
Storage: Micron M7 256GB+Seagate 3TB in acceleration mode
Backup: WD Blue 1T incremental for boot drive
PSU: Corsair AX860i
Display: Dell 2312HM
Cooling: H110i GTX
Keyboard: Topre Realforce
Mouse: Logitech G700s/G502s
OS:Win 10
https://linustechtips.com/topic/1002625-water-damaged-case/#findComment-12029640
Interesting. I'm currently letting it dry out, so i'll give the case a try tomorrow. Thanks
Some organic flux like the one I use with lead free solder are only water soluble. So I wash my boards after soldering and use some pressurized air to help it dry for a minute or two. Then i let it dry for a few minutes before testing the circuit. But I think the one you are seeing is just bad QA or you have really hard rain water which leaves residue when it dries. You can try to clean it with some rubbing alcohol.
PSU: Corsair AX860i
Cooling: H110i GTX
OS:Win 10
https://linustechtips.com/topic/1002625-water-damaged-case/#findComment-12029699
I'm thinking it may just be bad QA because the rain was relatively light last night. Either way I'll try some rubbing alcohol.
https://linustechtips.com/topic/1002625-water-damaged-case/#findComment-12029728
Water damage? Don’t think that’s how it works. It isn’t a basement. Clean it and send it.
https://linustechtips.com/topic/1002625-water-damaged-case/#findComment-12029758
