  • entry
    1
  • comments
    3
  • views
    1,119
NEED HELP FOR PROPER PART SELECTION
FINAL SELECTION…..
==============================PRIMEABGB.COM(INR 350 EXTRA FOR SHIPPING)
1) ASUS X99 PRO==INR 25049
2) INTEL CORE I7 5820K==INR 28099
3) Gskill Ripjaws 4 F4 2400C15Q16GRK DDR4==INR 20635
4) ASUS STRIX GTX 970==INR 28866
5) NZXT H440 BLACK==INR 8599
6) CORSAIR AF140 QUIET==INR 899
=============================AMAZON.IN(INR 668.89 SHIPPING)
7) WD 1TB BLACK==INR 5750
8) SAMSUNG 850 EVO 120GB SSD==INR 5085
9) LG 25UM65 ULTRAWIDE MONITOR==INR 16919
10) CORSAIR CS750M 750W GOLD==INR 7396
11) CORSAIR H100I CPU COOLER==INR 8150
12) LG GP50NB40 EXTERNAL DVD WRITER==INR 1520
13) LENOVO KM4801 WIRED COMBO==INR 800
I AM FROM INDIA
NEED HELP ON THE ABOVE RIG
WILL BE USED FOR ALL 3D SOFTWARES AND VIDEO EDITING SOFTWARES
BY BUDGET IS NOT ABOVE $2550
3 Comments
mchllatham03
Posted
Your parts selection seems to be very well thought out and it should be a very powerful pc.  I have a very similiar build (same cpu, cpu cooler, ram, and case), but i would really recommend upgrading the front intake fans and using the corsair af140 fan as an exhaust.  As you know, the front of the h440 is completely closed off except for the right side and bottom, so a more pressure optimized fan would definitely benefit you.  I replaced the stock fans with 3 noctua nf-f12 2000 rpm industrial fans and the airflow was significantly improved, but I'm sure the standard nf-f12's would work beautifully as my fans do get a little noisy at 100% speed, but it is easily controlled with the asus fan expert software.
IronGamart
Posted
I would reccomend you to get a R9 290X from AMD, is cheaper, have better computing cabpabilities that the gtx 970, has supprt for 10 bit colour depth, and just costs $300.
The rest of the parts are fine, but if You can get a 5960X
