  • entry
    1
  • comments
    6
  • views
    1,257
System upgrade/build,with current system specs
http://nz.pcpartpicker.com/p/PmTfCJ
1: Intel Core i7-4790K Processor (8M Cache, up to 4.40 GHz)
2: Kingston HyperX Savage 32GB Kit (4x8GB) 1866MHz DDR3 Non-ECC CL9
3: Samsung 850 Pro 256GB 2.5-Inch SATA III Internal SSD (MZ-7KE256BW)
4: EVGA GTX 980 SC ACX 2.0 4GB GDDR5 Graphics Card
5: Noctua NH-D15 Premium CPU Cooler
6: ASUS MAXIMUS VII HERO Z97 ATX DDR3 2600 LGA 1150 Motherboards
7: BenQ GL Series GL2760H 27-Inch Screen x2
I'll be gutting my case 600t and putting in the following items, upgrading up from:
1:Intel Core i7-3770 3.40 GHz Quad Core Processor
2:Patriot Viper Xtreme 8GB 1600 CL11
3:1TB 8GB-NAND, 64MB CACHE, SERIAL ATA/600, 3.5INCH (os on it, it will become storage,page filing)
4:EVGA GeForce GTX 660 3GB GDDR5 Video Card
5:Thermaltake CLP0564 Frio Dual 120mm CPU Cooler
6:GIGABYTE GA-Z77X-UD3H Intel 7 Series Motherboard
As for PCpartpicker the pricing is much higher than current market cost on most parts I've picked.
this build is running me right around $2000-2100, as for the parts I'm taking out i will put them into another machine for my brother.
blogentry-191328-0-85958100-1424163902_t
blogentry-191328-0-15222100-1424163909_t
blogentry-191328-0-60592500-1424163896_t
6 Comments
Brad.Neil
Posted
That's quite an amazing machine, I can say anything bad about it.
davidgr95
Posted
Personal preference: Swap out getting to 16GB of RAM and get better monitors.  Not sure what the selection is like in NZ but I am sure you can get something that at least looks better.  If you would invest so much into a system, invest a similar ratio into peripherals.  But other than that, super awesome build!
Kenjinn13
Posted
I have a 32GB kit that's 4x 8GB sticks coming, 1866hz cl9 kit from hyperX. the other machine had a total of 24GB of ram. As for the monitors I'm not looking for 4k or anything beyond 1920x1080 for awhile so the $200-$300 per monitor is fine. as long as it meets my refresh and size preferences.
Kenjinn13
Posted
nope, games, streaming and video editing all at the same time
