I changed my cpu cooler from a fan to ML240L RGB aio cooler, I put the radiator on the front and moved the 2 fans to the top. Now every so often I hear a noise like a phone vibrating on wood, it goes on for about 5 / 10 seconds, then stops for about 1 / 2 minutes.
Anyone have any idea what the noise could be?
https://linustechtips.com/topic/995984-weirded-noise/
it might be the bearing of the fans they might have gone bad or they might be something else like the fans that came with your aio are bad if the ones from before were good
₵₱Ʉ     ł5 8600₭
mσthєrвσαrd     αsrσck z370 kíllєr slí/αc
PSU     Rosewill CAPSTONE 550M
D҉i҉s҉p҉l҉a҉y҉(s҉)     B҉e҉n҉Q҉ V҉A҉ L҉E҉D҉ E҉y҉e҉-c҉a҉r҉e҉ M҉o҉n҉i҉t҉o҉r҉ 2҉2҉ I҉n҉c҉h҉
ᶜᴼᴼᴸᴵᴺᴳ     ᶜᴼᴼᴸᴱᴿ ᴹᴬˢᵀᴱᴿ ᴹᴬˢᵀᴱᴿᴸᴵᵟᵁᴵᴰ ᴸᴵᵀᴱ 120 ᴬᴵᴼ
κεψß⊕αrd     gεηεrïς uηηαmεd ςhεrrψ mx ßレuε ƒακε mεςhαηïςαレ κεψß⊕αrd
MƠƲƧЄ     ƦƛȤЄƦ ƇӇƦƠMƛ ƊЄƛƬӇƛƊƊЄƦ ЄԼƖƬЄ 2017
ѕoυɴd     eѕтoɴe вeѕт coмpυтer ɢαмιɴɢ нeαdѕeт нeαdвαɴd wιтн мιcropнoɴe мιc хιвerια v10 нeαvy вαѕѕ ѕтereo ɢαмe нeαdpнoɴe wιтн lιɢнт ғor pc ɢαмer
ФPΞЯДΓIИG SУSΓΞM     ЩIИDФЩS 10 БЯФ
https://linustechtips.com/topic/995984-weirded-noise/#findComment-11975081
