Posted November 10, 2018 Hi guys, Since i mount this pc (see in signature) every time i unplug the PSU or turn off the PSU button, i will get a weird issue on the boot only on the first time. It will turn on work for 2 seconds then auto reboots and everything works perfectly. If i only shutdown normally it wont do the same thing. It only does that issue if it gets complete out of power. i can play for hours and im even checking gpu-z to see if gpu gets power enough and everything works normally. Thanks Asus Z390 Primei5 9600KNoctua NH-12us2x8Gb HyperX Fury 2133 MhzRtx 2070 Msi Gaming Z 8GEvo 860 500gbSeasonic M12sII 620Watts EvoLg 24GM79GZowie EC2-BHyperX Alloy FpsHyperX Aplha HeadSet Link to comment https://linustechtips.com/topic/993153-weird-issue/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 10, 2018 This might be the CMOS solving problems. That is probably normal Link to comment https://linustechtips.com/topic/993153-weird-issue/#findComment-11950060 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
