building my self a  New but old (used) workstation but that still can game just fine on max settings in games for 1440p
CPU:e5-1650 6c/12t
MOBO:MSI X79A-GD45
RAM: 1 stick of Hynix 16GB PC3L-10600R DDR3 ECC (1333)
GPU:PNY NVIDIA GTX 1080 8GB XLR8
SSD:120GB Hp
CPU COOLER:EVGA CLC 240 Liquid
CASE:EVGA DG-76 Alpine White Mid-Tower
PSU:CORSAIR HX Series Semi-Modular HX850
Total Came out to 910$
Plan is to Overclock the 1650 to 4.5 or 4.6ghz. Has any one gotten over 4.6ghz 24/7 clock?
Hopefully this will be a better rig than my i5 7600k @5ghz setup for Cad and modeling but hold close to the same frame rates in gaming.
https://linustechtips.com/topic/980077-building-my-first-x79/
Get a 275R or something so your CPU doesn't bake but other than that fine
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/980077-building-my-first-x79/#findComment-11828179
CPU:e5-1650 6c/12t
MOBO:MSI X79A-GD45
GPU:
SSD:120GB Hp
X79 is still relevent these days! I would get this motherboard: https://www.asus.com/Motherboards/RAMPAGE_IV_EXTREME/ because you will have more overclocking headroom and more RAM to upgrade to. I would also add in a 1TB HDD for game storage and maybe find a kit of ram like 2x8GB sticks, so you can get dual channel. What CPU cooler are you using? What xeon are you referring to, V1. V2, V3, ect.....?
https://linustechtips.com/topic/980077-building-my-first-x79/#findComment-11828270
well I was on a 900$ budget and ordered everything already but ddr3 server ram is cheap! and the e5-1650 v1. ill add more Hd when I run into it cause I only play like maybe 2 games
https://linustechtips.com/topic/980077-building-my-first-x79/#findComment-11828283
I want to build an X79 PC myself someday, but right now, I dont have the money. You should be able to get 4.5GHz on the e5-1650 at like 1.375v, something like that. How did you get your motherboard so cheap by the way. Oh, and yes, of course this new rig will be better than your 7600k at 5.0GHz, we are comparing 4 threads to 12 threads after all ?
https://linustechtips.com/topic/980077-building-my-first-x79/#findComment-11828301
Ebay boss! its a magical place hahah and this is true!
https://linustechtips.com/topic/980077-building-my-first-x79/#findComment-11828310
I sincerely hope your PC build goes really well. I have a xeon x3440 overclocked to 3.8GHz at 1.2V paired with an rx 570. Then, Im getting a better case and a better CPU cooler. I cant wait to see what yours turns out to be like, it will give me some ideas on how to setup my rig ?
https://linustechtips.com/topic/980077-building-my-first-x79/#findComment-11828317
What about VRM heatsink ?
Did you remove it to take this photo ?
CPU : Core i7 6950X @ 4.26 GHz + Hydronaut + TRVX + 2x Delta 38mm PWM
MB : Gigabyte X99 SOC (BIOS F23c)
RAM : 4x Patriot Viper Steel 4000MHz CL16 @ 3042MHz CL12.12.12.24 CR2T @1.48V.
GPU : Titan Xp Collector's Edition (Empire)
M.2/HDD : Samsung SM961 256GB (NVMe/OS) + + 3x HGST Ultrastar 7K6000 6TB
DAC : Motu M4 + Audio Technica ATH-A900Z
PSU: Seasonic X-760 || CASE : Fractal Meshify 2 XL || OS : Win 10 Pro x64
https://linustechtips.com/topic/980077-building-my-first-x79/#findComment-11828366
No thats how the seller is selling it. Dosn't have it, Diddnt notice cause Never seen this board before till after I checked out the specs and ordered it. But I can cnc some heat sinks for it no problem
https://linustechtips.com/topic/980077-building-my-first-x79/#findComment-11828369
