yeah the title says it all my DVD burner can't burn anymore
and yes i know DVD's are the past and you can download everything from the internet but i don't have good internet connection it's like  1mb down and 24kb up so yeah not really great so anyway
it works fine i can use it for installing windows and install games from the DVD but it can't burn anything
every time i  want to burn use empty disc this come up
Manners Maketh Man
https://linustechtips.com/topic/97676-dvd-burner-not-burning/
If it is not a faulty SATA cable or port, then the DVD drive is faulty.
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
https://linustechtips.com/topic/97676-dvd-burner-not-burning/#findComment-1306341
Dvd's are not a thing of the past and are used alot today, maybe for people that use a pc for gaming yes dvd is not used at all but for a pc that is used for everything else, a dvd is very important.
on the matter of your dvd not working did you load a clean empty dvd? and also try using something like poweriso instead of the windows default.
http://www.poweriso.com/
Please Quote so i know you have replied. | If we have provided a solution to your problem mark it with answer found.
And also please read the COC and avoid the embarrassment and lecture that will ensue.
https://linustechtips.com/topic/97676-dvd-burner-not-burning/#findComment-1306354
i tried 5 DVD's and non of them work i used nero and poweriso still nothnig
Manners Maketh Man
https://linustechtips.com/topic/97676-dvd-burner-not-burning/#findComment-1306448
ok but it works fine i can't use it for reading media files or installing games and windows if it's faulty then  everything is not going to work
Manners Maketh Man
https://linustechtips.com/topic/97676-dvd-burner-not-burning/#findComment-1306455
